Inventor General
Valued Mentor
Logos_Atum
Message 1 of 3 (167 Views)
Simple Ilogic question
167 Views, 2 Replies
03-15-2013 08:18 AM
Hello there,
I´d like to ask a very simple question about Ilogic.
I need to change the length of geometry by a text parameter.
How to do this?
I tried this:
Also I searched Youtube but I have not found anything yet
Any help would be greatly appreciated
If widthselection="420" Then
Parameter(d11)=725mm
Parameter(width)=420mm
ElseIf widthselection="620" Then
Parameter(d11)=1075mm
Parameter(width)=620mm
ElseIf widthselection="820" Then
Parameter(d11)=1425mm
Parameter(width)=820mm
EndIf
- 2500K @ 4.2Ghz- 8GB - Radeon7970 -
- Xeon 1230V2 @ stock Ghz- 32GB - W7000-
- 2x Xeon 2670V2 - 64GB - W7000 -
- Factory Design Suite Premium Subscription-
Distinguished Contributor
danvang
Message 2 of 3 (146 Views)
Re: Simple Ilogic question
03-15-2013 09:04 AM in reply to: Logos_Atum
remove the "mm" after your numeric values. The parameter should already have a unit defined. So your code should be.
d11=725
width=420
d11=1075
width=620
d11=1425
width=820
End If
Valued Mentor
Logos_Atum
Message 3 of 3 (127 Views)
Betreff: Simple Ilogic question
03-15-2013 03:04 PM in reply to: Logos_Atum
Thank you very much...
I will change it on monday :smileyhappy:
Kind regards
Daniel
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
