Inventor General
New Member
riby13
Message 1 of 3 (217 Views)
Simple Dynamic Hinged Door Model
217 Views, 2 Replies
10-23-2013 10:55 PM
I'm sure you more knowledgeable gurus out there will have a quick answer for this. I'm trying to create (what should be) simple model of a hinged door.
The frame is constructed of an extruded profile and so is the "insert" or door panel
I have been able to create this with some sub-assemblies but it does not allow me to operate (hinge open) the door in the model.
I initially thought that I could have the insert profile in an assembly that is unconstrained and then I could size the insert with constraints relative to the frame extrusion in a higher level assembly. But can’t seem to get it to work
I’m relatively new to the 3d world so I feel my road block is not understanding exactly how to make the model dynamic and yet functional.
Any Help at all would be a great. I’m losing sleep over something that I’m sure is an easy concept
So to summarize I need to create a model that is;
 Driven by one sketch (width and height)
 Made of a frame extrusion and an insert extrusion (aka door panel)
 a functional hinging model
Valued Contributor
yannicknielsen
Message 2 of 3 (204 Views)
Re: Simple Dynamic Hinged Door Model
10-24-2013 12:36 AM in reply to: riby13
As I understand it, your hinge is a subassembly in a top assembly.
When you put subassemblies in another assembly they cannot move, unless you right click them and choose "Flexible".
in order for that to work, you also have to make sure that your hinge can move in its own assembly.
Hope this helps!
Product Design Suite Premium 2014
Inventor 2014 Professional
Windows 7 Professional 64 bit
Intel Xeon E3-1240 @ 3.4 ghz
Nvidia Quadro 600
8.00 gb RAM
JDMather
Message 3 of 3 (189 Views)
10-24-2013 08:36 AM in reply to: riby13
If you can't figure it out - attach your assembly here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
