I would like to ask about the Autodesk Inventor Student Version. Is that possible for this software to integrate with Matlab SimMechanics? I try to find the solution online but didn't get any success method to do it. Or do I need the Full version to do that?
Thank you.
Solved by JDMather. Go to Solution.
Thank you.
Student version is full version. The exact same functionality as commercial license - only the license terms of use (EULA) is different.
You might look into Dynamic Simulation built into Inventor in place of MatLab.
The CADWhisperer YouTube Channel
I have the same problem !
I m working with Inventor 2013 student version, and also a 2015 student version, I need to export my assembly in Matlab.
I ve tried to reinstal my version but there is no differences, I still can't have the SimMechanics menu for the XML files export .
I have also tried to install the User tool from the SDK folder, of the inventor 2013, an Add In button appears but there is no SimMechanics link to export my data in XML
I have also tried the 2015 version, with this one even if I instal the Users Tools from the SDK folder I have no Add in menu...
Can someone help me please ?
Thank you in advance,
