Inventor General
Atlas_Inventor
Message 1 of 8 (607 Views)
Accepted Solution
Sideways Drawing
607 Views, 7 Replies
11-01-2012 11:56 AM
I don't know if I did anything, but the drawing I'm doing completely went sideways, the other sheets are normal, but this one turned. Any help turning it back could be appreciated.
*Expert Elite*
Message 2 of 8 (601 Views)
Re: Sideways Drawing
11-01-2012 12:08 PM in reply to: Atlas_Inventor
Rotate your monitor clockwise 90° while working on that sheet.
Can you attach the file here?
If you right click on that sheet and select Edit Sheet - what does it show for the Orientation? (Portrait or Landscape)?
Did you reboot the computer and the behavior persists?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Atlas_Inventor
Message 3 of 8 (586 Views)
Rotating the monitor will change the way the mouse behave...
11-01-2012 12:21 PM in reply to: JDMather
Rotating the monitor will change the way the mouse behaves (push mouse away, it would go to the right, etc.) so I'll just work with how it is for now.
The Orientation is still set to Landscape. I tried switching to Portrait, then back to Landscape and nothing.
Nothing changes with a reboot.
*Expert Elite*
Message 4 of 8 (560 Views)
Re: Rotating the monitor will change the way the mouse behave...
11-01-2012 01:23 PM in reply to: Atlas_Inventor
Have you installed SP 1.1?
*Expert Elite*
blair
Message 5 of 8 (543 Views)
11-01-2012 02:22 PM in reply to: Atlas_Inventor
Select the sheet in questions, RMB click on the sheet in the Drawing Browser box, select Edit Sheet and change the orientation from Portrait to Landscape.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Atlas_Inventor
Message 6 of 8 (539 Views)
11-01-2012 02:29 PM in reply to: blair
It's already in Landscape format, everything is rotated 90 deg, not just the sheet. When you export as a PDF it still comes out as a regular landscape format.
*Pro
sbixler
Message 7 of 8 (495 Views)
11-02-2012 04:07 AM in reply to: Atlas_Inventor
I vaguely recall many years ago that there was a way in which you could get a drawing (.idw) to rotate in 3D space, which was useful mainly for entertainment... (some of us don't get out much!).  I don't recall how that was accomplished, nor do I know whether Inventor still has that ability.  But your situation looks like it accidentally got rotated and saved that way.  Post the file and see if anyone can figure it out.
Atlas_Inventor
Message 8 of 8 (469 Views)
11-02-2012 07:07 AM in reply to: sbixler
After you said that, I figured it out immediately, I have a 3DConnexion Mouse and just hit the rotate button!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
