Inventor Forum
Shrink wrap a different position rep
5 REPLIES 5
devlybbert
544 Views, 5 Replies
I would like to shrink wrap a sub assembly in two different position reps. It seems to me like you can only shrink wrap while in the Master position rep. Is there a way to shrink wrap in a different position rep?
5 REPLIES 5
chun123
in reply to: devlybbert
Try the steps below:
1. Create Position Rep(new and activate position---Pos1/Pos2,select the position constraint then override,check on Suppresion=Enable,and input value)
2. Activate Pos1 or Pos2
3. Shrinkwrap
4. New Assembly->place Shrinkwrap file (using LOD->New Substitute->select part file)
in reply to: chun123
Look at this!!:
I've made the position - one simple constraint changed, so that the seat is up...
But no matter what I do, the Shrinkwrap looks like this: 😞
The Shrinkwrap in Master position looks perfect.
No error message appears.
When choosing the shrinkwrap options, the Preview doesn't show any scattering of parts.
johnsonshiue
Hi! I have seen this behavior before. I vaguely remember it was fixed in later service pack or release. What release of Inventor are you on?
Thanks!
Software Test Engineer
in reply to: johnsonshiue
I found a solution!!! 😄
I opened up a new assembly - placed the seat assembly in the new assembly - then, I was able to create a shrinkwrap with no errors!
Weird - but it fixed my problem! 😄
