Inventor Forum
Shrink part in middle
3 REPLIES 3
pball
812 Views, 3 Replies
I have a part which is lets say 10ft long. Now I need to modify that to be 9.5ft. Is there a simple way to remove that .5ft from the center of the part?
I just need a way to cut out a .5ft section in the middle and then put the two remaining pieces back together. Doing this would be much easier than editing the sketches for the part, especially since I may have to change the amount that is cut out and that would change the number of holes and features.
Attached is a picture of the parts i have to edit and some lines to show the section that needs to get removed.
3 REPLIES 3
JDMather
in reply to: pball
Split
Move Body
Combine
PaulMunford
in reply to: pball
Use patterned features rather Tahoe sketching them all. Remember that you can suppress features conditionally.
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
pball
in reply to: PaulMunford
Unfortunately the features aren't that evenly spaced so using a pattern wouldn't work too well. I went with split/move method and although it takes a few steps and some time, I can change amount cut out with a single parameter. Even went as far to link the individual pieces in the assembly.
