I have a part which is lets say 10ft long. Now I need to modify that to be 9.5ft. Is there a simple way to remove that .5ft from the center of the part?
I just need a way to cut out a .5ft section in the middle and then put the two remaining pieces back together. Doing this would be much easier than editing the sketches for the part, especially since I may have to change the amount that is cut out and that would change the number of holes and features.
Attached is a picture of the parts i have to edit and some lines to show the section that needs to get removed.
Solved by JDMather. Go to Solution.
Split
Move Body
Combine
Unfortunately the features aren't that evenly spaced so using a pattern wouldn't work too well. I went with split/move method and although it takes a few steps and some time, I can change amount cut out with a single parameter. Even went as far to link the individual pieces in the assembly.
