Seems like this should be easy enough to do but can't seem to pin it down.
I have a fixture that has two parts on it and has a change over. I will be using the same part in the assembly at two different locations. I would like to show in the drawing the change over from part to part.
I've tried representations but whatever constraints you put in one occur in all of them, unless there is a setting to turn that off so it is only in one. I don't want to use an IPN as I would have to tweak a many more parts.
What's the best way to go about this?
Any help appreciated.
~Matt
Solved by Curtis_Waguespack. Go to Solution.
Hi MJuric2,
It sounds like you want to create a Positional Representation.
I hope this helps.
Curtis
