Did I miss what us subscription users who were given Showcase back are supposed to do to install/activate it?
I expected to see it on the subscription site but its not there?
Or has Autodesk just not gotten around to adding it yet? or what?
Solved by ChrisMitchell01. Go to Solution.
I downloaded my clients software it was included in the package it was not a seperate download for them anyway..
When I installed Inventor it was there....
Showcase 2015 will be made available for both Product Design Suites Premium and Ultimate 2015 editions by end of Q1 and will check for appropriate licensing to run • Alias Design 2015 will be made available for Product Design Suite Ultimate only by end of Q1 and will check for a Ultimate 2015 license to run
Soooooooooooooooooooooooo by 31MAR2015, then?
Rusty
End of Q1 for Autodesk == End of April, so hopefully you should it next week.
-Chris
Thanks for the update Chris!
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
mcgyvr,
Please try this again.
Others seem to be seeing it show up for them.
Let us know.
blair,
It should be a standalone install.
FYI
@bob.holland wrote:
mcgyvr,
Let us know.
Nope still not there..
Hello all!
Apologies for the confusion regarding the Showcase 2015 download link issue. We are currently working towards a solution and I will be sure to update this thread once that happens. Please let me know if you have any questions in the meantime. Thank you!
Update: If you would like to download your Autodesk Showcase 2015 product please visit our Virtual Agent.
Which serial number should we use?
We have a standalone copy of showcase (for a non PDSU PC), so I have downloaded it via the link in subscription centre.
I've used that download image to install the software on to a machine with PDSU on it. Is this correct or will there be a separate "PDSU edition"?
Using the image I have, should I be able to use the PDSU serial number to authorise it? It says that it's invalid when I try.
Thanks for any advice
Rory
Hi @Rory_M!
I will send your Autodesk Showcase 2015 serial number to you in a private message. In the future, you should be able to find your serial number in your Subscription Center account.
If you have any other questions please respond to this post.
Thank you!
Hi Jessica, thanks for the message and your help on this. You've asked me to respond in this thread so here we go:
Unfortunately, the serial number you've supplied isn't the one I'm looking for.
We have a number of Product Design Suite Ultimate licenses, which obviously came with Showcase "in the box" in 2014.
As I understand it, Showcase was initially removed, and then added back to the 2015 version.
I'm looking to install this Showcase that is part of our PDSU 2015 suite.
The serial number you have given me is for a completely separate Showcase network license that we have which is reserved for machines that don't have PDSU installed.
I've tried to use the PDSU serial number for Showcase on these PDSU machines but it won't accept it.
Does this make sense? If not please let me know.
Regards
Rory
Edit - Just had another look at the downloads section.
We originally had Showcase 2015 available for download as a seperate entity. This is because we have a network license of it that isn't part of a suite. At that point I downloaded everything, this was the only Showcase available to me.
There is now a link to another Showcase download which is listed as part of PDSU 2015. This wasn't there the other day when I downloaded and installed PDSU.
I've used the standalone Showcase installer. Should I uninstall and download and use the one that's listed underneath PDSU with my PDSU serial?
This is getting complicated....!
Hi Rory,
Yes it's complicated....
There are 2 versions of Showcase 2015. The first version does not run with a PrDS license, but the second version gained this capability. You've already discovered this...
So yes, you can only license Showcase from a PrDS license by actually installing from the later Showcase download. Code was changed to put the suite license cascading in place. You'll need to uninstall & then reinstall, unfortunately.
Hope this helps,
Chris
Hello Chris,
We are subscription customers. Where do I go to download the subscription version of Showcase 2015? Please let me know because I'm unable to download from the Virtual Agent.
Thanks!
