Hey.
I'm having problems importing Inventor parts into Showcase 2014. Any part, I've tried creating a brand new Part, modelling a box and importing that and it fails. I've tried the Inventor sample models, they fail. I've tried sample files from Inventor 2014 & 2013.
I'm running Inventor 2014 SP1. I'm running Windows 8.1 64bit.
*I've downloaded and installed the model documentation hotfix for rse.dll and validated the version as being 18.0.15100.2, the problem still persists. The models convert, but then fail to load.
I also have the latest Showcase 2014 hotfix installed.
I've tried completely reinstalling showcase, directconnect 2014, still doesn't work. I'm completely at a loss to why this isn't working now.
The above is very confusing. Part1.ipt is a brand new part with just a box modelled, one attempt it converts then the next it doesn't... all done in the same session.
Any help would be appreciated, please note the steps I've already taken to remedy this.
Cheers in advance.
Are you using Windows 8.1? One of my students had the same issue after "upgrading" to 8.1. It worked fine in 8, but after 8.1 ... this happened.
The workaround was to export everything to a STEP file, then load the STEP file from within Showcase.
Rusty
