I have an assembly. During the making the of the assembly we use a small guage made out of thin sheet metal to check a few settings. For this reason I place the guage model in the assembly so that it shows up on the BoM and on the parts list.
However, I would like for the gauge not to be included in the mass, inertia and CoG calculations as it won't be included in the final assembly.
I've tried reference and phantom and they both make the gauge dissapear off the parts list. Is there anyway to achieve what I want without making a new assembly file?
thanks,
John
Solved by Curtis_Waguespack. Go to Solution.
use a virtual component
Hi johnster100,
If I understand correctly, you can edit your gauge iProperties and override the Mass Properties setting the mass to zero. This will allow it to show in the BOM, but it will not impact the mass properties of the assembly.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-30E3BAE2-0C06-45E2-B0D7-8686361651A9
Edit: In re-reading the original post, it seems you do not really need the part in the assembly. Therefore mcgyvr's suggestion that you use a virtual part is the best solution.
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-53A45932-3FDD-4258-9F63-69D8CBFE8FEF
I hope this helps.
Curtis
