Inventor General
elizabeth.dawe
Message 1 of 10 (734 Views)
Shell Command Help
734 Views, 9 Replies
10-04-2012 06:22 AM
I have been working on a project, and some of the dimensions have changed so I decided to remake the parts from scratch. But when I tried to use the Shell command on one of my new parts, I get the error "The attempted Shell operation would require a large topology change. Try with a smaller thickness."
I've tried smaller thicknesses, but nothing works. I'm just confused because it is very similar to the old part that I Shelled without a hitch.
I've attached both parts. I'm trying to Shell the inside of the part, through the circular opening. Any help or suggestions would be appreciated.
Elizabeth
Using Autodesk Inventor 2013
*Pro
jletcher
Message 2 of 10 (725 Views)
Re: Shell Command Help
10-04-2012 07:02 AM in reply to: elizabeth.dawe
Can you post a pic I don't have 2013 loaded here.. but try a thicker shell to see if that works. Sometimes small in a shell command error means thicker. So if you had .125 try .187 not .100....
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
elizabeth.dawe
Message 3 of 10 (719 Views)
10-04-2012 07:07 AM in reply to: jletcher
Thanks a lot, making it thicker worked!
JDMather
Message 4 of 10 (715 Views)
10-04-2012 07:08 AM in reply to: elizabeth.dawe
You didn't indicate your desired shell thickness on the second part.
What is (8-5.136125959)/2=?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
JDMather
Message 5 of 10 (711 Views)
10-04-2012 07:11 AM in reply to: elizabeth.dawe
You better check your results and verify the design intent.  Do you understand the significance of my first question?
elizabeth.dawe
Message 6 of 10 (702 Views)
10-04-2012 07:14 AM in reply to: JDMather
No, I don't understand exactly what you're saying
JDMather
Message 7 of 10 (696 Views)
10-04-2012 07:21 AM in reply to: elizabeth.dawe
What would be the maximum wall thickness you could have with this area shelled?
(when you go over that max thickness - it works, but it isn't shelled in this thin area above the two green lines)
In your first part it is shelled in this area.  Which solution do you really want?
BTW - you are still duplicating dimensions and not using symmetry about the origin.  You might read this document http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
elizabeth.dawe
Message 8 of 10 (687 Views)
10-04-2012 07:30 AM in reply to: JDMather
I realized that afterwards. I'm going to change the thickness and some dimensions.
When I learned how to use SolidWorks, I was taught to start at the origin and go from there in one of the quadrants, not for symmetry about the origin. I guess old habits die hard.
I'm just starting to use Inventor so that document is very helpful. Thanks!
JDMather
Message 9 of 10 (684 Views)
10-04-2012 07:33 AM in reply to: elizabeth.dawe
When I learned how to use SolidWorks, I was taught ...
You were taught incorrectly.  The proceedure is the same in SolidWorks and Creo (Pro/E).
It is a question of using the "best" and "most efficient" technique, not right or wrong.
elizabeth.dawe
Message 10 of 10 (676 Views)
10-04-2012 07:48 AM in reply to: JDMather
Ok...
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
