Inventor Forum
Sheetmetal holes?
3 REPLIES 3
175 Views, 3 Replies
Sheetmetal holes?
Hi all, I have a sheetmetal panel. The panel has 4 holes in a pattern, all
selected at the same time and with the same diameter. How can I change the
diameter of only one of the holes? TIA, Bob
3 REPLIES 3
Rmb on the hole in the browser, and edit. Hold the control key and select
the one you want different to remove it from the rest that are selected. Ok
to finish the edit, then rmb on the sketch in the browser for the holes and
share it. Now add another hole using the point that you removed from the
other hole set.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Bob Johnson" wrote in message
news:B32208D7A81F1BD4B66998F409C510C0@in.WebX.maYIadrTaRb...
Kent, will this also work, RMB on hole in browser, select edit feature, ctrl
key/select hole center point/OK, select hole tool, enter new hole size/OK?
Thanks again, Bob
"Kent Keller" wrote in message
news:88CEF94E0ADD9B27E6DFB81B296523DC@in.WebX.maYIadrTaRb...
Ok
and
> other hole set.
> Kent Keller
all
the
Not if I am following correctly (always suspect that I am not)
AFAIK you can not have two hole sizes on a sketch unless the sketch is shared. It sounds
to me like that is what you are trying to do. If you just share the sketch then
everything will be happy.
Kent
news:E607262317971A6A1E0E5AD969846BA2@in.WebX.maYIadrTaRb...
> Thanks again, Bob
