Inventor Forum
Sheet unfold
4 REPLIES 4
kir_01
314 Views, 4 Replies
Sheet unfold
Hello me again with a problem of unfolding a part please can any1 help thks
4 REPLIES 4
JDMather
in reply to: kir_01
You should indicate when you are not using the latest release.
Sketch1 is not constrained - you might read this document.
http://home.pct.edu/~jmather/skillsusa%20university.pdf
Shell will not result in correct geometry.
Instead of Extrude and Shell - you should be using the sheet metal tools.
Missing a bend (among other problems) at the intersection of the horizontal and arced faces.
How would you get the end face to unfold from your model?
kir_01
in reply to: JDMather
hello sorry next time will indicate my version infact was thinking to go through the sheet metal tools
but reaching the arc secgment i didnt know how to continue. the side profile i will weld them just wanted to ve the development
JDMather
in reply to: kir_01
You might put your version in your signature (see my sig at below) so that others don't respond with a later version solution you can't open.
Sketch1 is missing a horizontal constraint on this line (notice that I also changed it to construction linetype.
You have a very strange dimension on the angled line - use dimensions that can actually be measured (and manufactured).
These changes are all you need to create a Countoured Flange in Sheet Metal environment.
kir_01
hello sorry for late reply that exactly what i was lookin for thks
