Inventor Forum
Sheet metal material not correct
4 REPLIES 4
dominiekvanwest
465 Views, 4 Replies
I'm using Inventor 2013. For some reason the material in a sheet metal part is not linked to the Sheet Metal Rule.
In the attachment you see on the left side that the material TRPL5-7 (that's a material I created) is linked to the Sheet Metal Rule TRAANPLAAT_5_7. But if I select TRAANPLAAT_5_7 as Sheet Metal Rule in Sheet Metal Defaults (see right picture in attachment) the Material doesn't change to TRPL5-7.
What's wrong here?
Thanks in advance!
Dominiek
4 REPLIES 4
xingyuan
in reply to: dominiekvanwest
Hi Dominiek,
Would you mind upload the attachment?
Sam
[Sam Yuan]
[Sr. Software QA Engineer]
[Alias] Quality Assurance Team
Autodesk, Inc.
dominiekvanwest
in reply to: xingyuan
I don't seem to be able to edit my first post, so I'll add the attachment here
mrattray
In the sheetmetal defaults tab, change the material to "by sheetmetal rule". That will tell Inventor to use the material specified in the rule, as opposed to the overriding material you have selected.
Mike (not Matt) Rattray
dominiekvanwest
in reply to: mrattray
Oh, of course that's the solution. Just looked over it 🙂
Thank you!
