Inventor General
Distinguished Contributor
Message 1 of 4 (348 Views)
Accepted Solution
Sheet metal fold puzzle
348 Views, 3 Replies
03-11-2013 01:49 AM
O.k, if anyone is in the mood for some mental gymnastics this morning:
The left-hand part was created by someone else, using the bend part command in the "modify" tab.
The right-hand part was created by me using fold in the sheet metal environment, using the same sketch.
Why, please why, is my part shorter?
Inv 2013
*Expert Elite*
Message 2 of 4 (308 Views)
Re: Sheet metal fold puzzle
03-11-2013 05:20 AM in reply to: BarryZA
Bend Part command is not a sheet metal tool and doesn't take account Bend Allowance (sheet metal stretches when bent).
I wound not have used either method to create this part.
I am away from my Inventor computer so can't provide a demonstration on easy technique to model.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Pro
sbixler
Message 3 of 4 (304 Views)
03-11-2013 05:23 AM in reply to: BarryZA
The Bend tool sets the neutral axis of the material at the sketch plane, I believe, since Inventor knows nothing about the bending properties of the material; this makes the material deformation in this case all stretch and no compress.  The fold tool in Sheet Metal sets the neutral axis as directed by the active Sheet Metal Unfold Rule, by default at .44 times the thickness (or nearly halfway through the material).  So I expect that the sheet metal version would be more accurate.
Best practice, though, is to model sheet metal parts in the folded condition and let Inventor work out the flat pattern based on your k-factor or bend table for the specific material and forming tool.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 4 of 4 (303 Views)
03-11-2013 05:23 AM in reply to: JDMather
Thank's JD (as usual)
I was thinking K-factor had something to do with it. The sheet metal one is mine, the other one from the previous guy - for the record :smileywink:
I want to see if I can round off the decimals in the folded model and model it like you said sblixer. Nothing like being paid to fix someone else's mistakes.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
