I modeled this part and then converted to sheet metal so I could lay it flat and then have it laser cut for prototypes. However, I went in and assigned the bends it creates this extra cut out space for a punch but I dont want that. How do I go about making it just lay flat? What have you guys done to make something like this laser cutter compatible?
Solved by BeKirra. Go to Solution.
Solved by alewer. Go to Solution.
I don't think you'll be able too..
Extrusion 3 and 5 weren't done in Sheet metal ... therefore they can't go flat
I believe without going into it to far.. You'd want to put those bends in after you notch the squares ~ Extrusion 9
As the error message suggests, you have interfering plates. One of your tabs is interfering with your main body (see my attached image).
I modified your model to remove the problem area. It flattens, but it still requires a great deal of cleanup. Even though you can get it to flatten, there is no reason to use extrude+bend to create this model. It can (and should) be done with sheet metal features. You should also fully constrain your sketches.
Nice ...you went in much deeper than I did ...
It looks a lot better
I think that mateo710 has problem with creating bends as I had the same before.
And what you've pointed out is right, the flat pattern would be perfectly without any errors when all interferences are fixed.
To mateo710,
There won't be a problem if some features are created by using simple extrusion.
I attach a sample which has a tab made by "bend" while another made by "extrusion". Hope it would help you a little.
Awesome thanks guys that helped a ton. I got one more quick question, I'm trying to make than L shape on this bracket that's parallel to the face. I can't figure out how to make a second flange coming off the first
Something like this, Mateo?
Walter
Walter Holzwarth
