Inventor General
aaddekrom
Message 1 of 15 (531 Views)
Accepted Solution
Sheet metal Problem
531 Views, 14 Replies
11-09-2012 03:08 AM
Can't seem to find a sheet metal solution for this part.
Can someone help me in the right direction ?
Tried Rip & Bend and building it from face, solids etc.
IVP2013
*Expert Elite*
karthur1
Message 2 of 15 (494 Views)
Re: Sheet metal Problem
11-09-2012 10:14 AM in reply to: aaddekrom
I would say to use a contoured flange to get the basic shape, then add the flanges on the sides.
If you want to use what you have so far, you will have to add fillets (inside and outside) and add cuts where the flanges miter together.
*Pro
jletcher
Message 3 of 15 (489 Views)
11-09-2012 10:23 AM in reply to: karthur1
Not sure how the part was made but it sounds like it was extruded not using shet metal functions.
But putting in radius is not a way to fix it.
in sheet metal there is a command called Bend use that just pick the edge you want. it will make it a bend with the sheet metal radius.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
*Expert Elite*
karthur1
Message 4 of 15 (483 Views)
11-09-2012 10:40 AM in reply to: jletcher
What is this you are clicking?
I dont recognize that.  I am on 2013.
When I try the Bend command, I get an error when I apply it "Failed to extend body or create space for bend".
Distinguished Contributor
Message 5 of 15 (478 Views)
11-09-2012 10:55 AM in reply to: aaddekrom
I had never used the bend feature before to do this, but I tried it on '13 and it worked for me.
Larry Marshall
2013 Product Design Suite Ultimate
Windows 7 Sp1
Intel(R) Core (TM) i5-2400 @ 2.00GHz
6.00 GB of RAM
AMD Radeon HD 6570
*Pro
jletcher
Message 6 of 15 (463 Views)
11-09-2012 12:12 PM in reply to: karthur1
sounds like your radius may be to big or flange to small to accept radius. can you post picture of yours? When it is in preview. like my second picture.
James Letcher
*Pro
jletcher
Message 7 of 15 (462 Views)
11-09-2012 12:13 PM in reply to: jletcher
oh also the thickness has to match the sheet metal rule you are using.
James Letcher
*Expert Elite*
Message 8 of 15 (413 Views)
11-10-2012 05:49 AM in reply to: aaddekrom
I haven't gotten around to your solution yet, but you might want to take a look at the attached file.
It looked to me like you were doing too much work.
The finished sheet metal part is not so easy.  I see lots of suggestions - but no solution files.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
aaddekrom
Message 9 of 15 (351 Views)
11-12-2012 05:21 AM in reply to: JDMather
Thanks for your help.
I tried several "modeling" approaches until i decided to model it from surfaces.
Contour flange, Face & Fold, 3D solid & shell give (almost) the same geometry but the problem occurs when developing the flanges.
When i decide to cut and bend after solid & shell, it won't take all bends and cuts.
When i go with Face & Fold (see attachement), it won't make corner seams like it should, because there is always al little angle between the flanges. (The same with contour flange).
Aad
*Expert Elite*
Message 10 of 15 (345 Views)
11-12-2012 05:34 AM in reply to: aaddekrom
I would very rarely use Fold feature.
I will try to post one solution later today.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
