And ... Where can I find sheet metal.ipt template for Inventor LT 2012 ?
I seem to be failing to get "off the ground" here ... The "Sheet Metal" tab at top will not appear. Also, the "sheet metal.ipt" template is not in my files. Should I do a complete deinstall/reinstall? This is my first (or should I say, zeroth?) attempt at sheet metal, so I seem to be crawling on all 4's. Maybe more like on my belly ...
Thanks for your help! jb
Solved by JDMather. Go to Solution.
There is no sheet metal in Inventor LT.
The CADWhisperer YouTube Channel
