OK, maybe a silly question but a local search of my HD and a search on the subject here returned with zero results...
Where does one find the Inventor Sheet Metal Rules excel table for 2012 on a Windows 7 system?
All the documentation says it's located in the Documents and Settings directory, but Windows Vista eliminated that folder and thus it is not in Win7 either.
I can find the SheetMetalRules.xml file, but I need the excel table for modification.
Solved by jdkriek. Go to Solution.
"Documents and Settings" is now "C:\Users\" and "C:\ProgramData"
Don't think there is a Exel file for Sheetmetal Rules, it's all controlled in the style library.
C:\Users\Public\Documents\Autodesk\Inventor 2012\Design Data\
I did however find this, even though you still control it via the Style Library.
C:\Users\Public\Documents\Autodesk\Inventor 2012\Design Data\Bend Tables\Bend Table (in).xls
Jonathan,
Thanks.
I was just about to post this.
I was hoping to find the bend table and use it to modify it, but yes, I see the same info just needs to be put into the styles library. Just gotta figure out the right way...;)
Again, thanks
