Inventor General
Message 1 of 3 (105 Views)
Sheet Metal Problem
105 Views, 2 Replies
05-05-2012 05:46 AM
I have a master sketch part.
I have a simple sketch containing 3 lines.
I have derived this sketch from the master part into a new sheet metal part which was created using the make layout function in an assembly file.
I assigned a contour flange to the profile.
When I change the dimensions in the master part and revisit theassembly. The contour changes direction. Why?
Works fine if i created the sheet metal part not using the make layout.
Seems inventor is getting confused with coordinates somewhere within this functionality.
Message 2 of 3 (100 Views)
Re: Sheet Metal Problem
05-05-2012 06:39 AM in reply to: PACDrafting
See attached.
In Inventor 2012.
It doesnt work even if the part is created not using make layout.
Open the assembly first and take not of all contour flange directions.
Go into the master sketch file and change say the 1350 dim to 1550.
Then open the assembly. Note the direction of 2 contour flanges have changed. Whats doing here Autodesk?
Message 3 of 3 (74 Views)
05-06-2012 08:33 PM in reply to: PACDrafting
Any takers on this one?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
