Inventor Forum
Sheet Metal Holes
16 REPLIES 16
Message 1 of 17
228 Views, 16 Replies
Sheet Metal Holes
Well I just loaded 6, and working on my very first part. A sheet metal part.
In 5.3 when defining the depth of the hole, you were able to type in
"Thickness"
In 6.0 all you can type in is "Thickne"
Is this a bug?
16 REPLIES 16
Message 2 of 17
Keep typing. Mine "word wraps" but does accept the entire word, it just
truncates it.
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
(Remove All Numbers From E-mail)
"Ken Schumacher" wrote in message
news:7A731BB62D352F23FB63494BC94D74FA@in.WebX.maYIadrTaRb...
part.
> "Thickness"
> Is this a bug?
Message 3 of 17
Mine doesn't word wrap, it continues to beep
with every keystroke after the 7 character limit.
"Keith_Bradford" <7kbradford7@7scsfrigette7.com> wrote in message
news:03BF56D891D497D62CC59CBC22B3B464@in.WebX.maYIadrTaRb...
> truncates it.
> Keith Bradford
> CAD Director
> SCS/Frigette
> 817.293.5313
> www.scsfrigette.com
> part.
> > "Thickness"
> > Is this a bug?
Message 4 of 17
Wow. Sorry no can help. BTW- I can type in 12 characters.
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
news:39BCD9D740796C5E9B450AE598194A9B@in.WebX.maYIadrTaRb...
just
> > truncates it.
> > Keith Bradford
> > CAD Director
> > SCS/Frigette
> > 817.293.5313
> > www.scsfrigette.com
> > part.
> > > "Thickness"
> > > Is this a bug?
Message 5 of 17
Opps. I didn't pay attention. It changes to red after 6 numbers but I can
type in Thickness.
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
just
> > truncates it.
> > Keith Bradford
> > CAD Director
> > SCS/Frigette
> > 817.293.5313
> > www.scsfrigette.com
> > part.
> > > "Thickness"
> > > Is this a bug?
Message 6 of 17
The text also stays red, whereas before, the word "Thickness"
would turn black after typing in the last s.
> truncates it.
> Keith Bradford
> CAD Director
> SCS/Frigette
> 817.293.5313
> www.scsfrigette.com
> part.
> > "Thickness"
> > Is this a bug?
Message 7 of 17
Yes, i does accept the variable Thickness as desired. Sorry I can not
help.
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
news:5C2B9E727932085879F70F4F4ECC664C@in.WebX.maYIadrTaRb...
just
> > truncates it.
> > Keith Bradford
> > CAD Director
> > SCS/Frigette
> > 817.293.5313
> > www.scsfrigette.com
> > part.
> > > "Thickness"
> > > Is this a bug?
Message 8 of 17
Highlight the value, then RMB (Right Mouse Button) and select List
Parameters, then select Thickness.
HTH
Mike
part.
> "Thickness"
> Is this a bug?
Message 9 of 17
Hey Mike.
I can do what your saying, but it won't accept in for a depth.
Just for yucks, I tried it for the diameter, and that worked, but not for
the depth.
Thanks for the tip though.
-Ken
"Mike Maenpaa" wrote in message
news:8DAF52FC573019B25225713CA936E8AB@in.WebX.maYIadrTaRb...
> HTH
> Mike
> part.
> > "Thickness"
> > Is this a bug?
Message 10 of 17
It didn't work for me the first time either. I knew that it SHOULD work, so
I kept at it. I found out, that if you double click Thickness, I had more
consistent results.
Mike
news:232D46D844B928EA093535570ADADCB3@in.WebX.maYIadrTaRb...
> Hey Mike.
> the depth.
> -Ken
> > HTH
> > Mike
> > part.
> > > "Thickness"
> > > Is this a bug?
Message 11 of 17
Ok. Tell me this isn't bizarre.
If I go to Tools, Application Options, Text Appearance,
and change from Arial back to the default of Tahoma, it works fine.
Hello Autodesk?????
> Hey Mike.
> the depth.
> -Ken
> > HTH
> > Mike
> > part.
> > > "Thickness"
> > > Is this a bug?
Message 12 of 17
That has to be in the running for oddest bug...LOL
____________________
Sean Dotson
http://www.sdotson.com
...sleep is for the weak...
news:B5DF7EDF82665C1E1FA7BF45C304855A@in.WebX.maYIadrTaRb...
> Hello Autodesk?????
> > Hey Mike.
for
> > the depth.
> > -Ken
> > > HTH
> > > Mike
metal
> > > part.
> > > > "Thickness"
> > > > Is this a bug?
Message 13 of 17
Anymore, as Jane's Addiction said, "Nothing's shocking."
> Hello Autodesk?????
> > Hey Mike.
for
> > the depth.
> > -Ken
> > > HTH
> > > Mike
metal
> > > part.
> > > > "Thickness"
> > > > Is this a bug?
Message 14 of 17
boris.vaintroub
Ken,
I've just tried this on IV5.3 and 6.
It worked for thickness and diam.
Mike, Thanks for tip.
B. Vaintroub
Designer
Message 15 of 17
boris.vaintroub
BSW
Another way, we have created user parameter "t" in SM template with equation "thickness",
so in hole dialog we are typing just "t" instead of "thickness"
B. Vaintroub
Designer
Message 16 of 17
In my experience, it looks likeIV variable (parameter) input is case
sensative. I kept inputing what I knew was correct & it didn't work until I
got the case (caps & lower case) right. Did anyone else notice this or am I
in the Twilight Zone? (BTWForest Whitaker is pretty good on that new
show -Rod Sterling's a tough act to follow).
Gary
gcross@crossdesign.com
part.
> "Thickness"
> Is this a bug?
Message 17 of 17
I believe Inventor has always been case sensitive.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Gary Cross" wrote in message
news:2FB2226092C92ED6E6F651BEC54EA9AB@in.WebX.maYIadrTaRb...
I
I
