I have a sheet metal part where I selected an incorrect edge when creating flanges, is there an easy way to deselect the edge? I can add edges and I can select the glyph for a specific edge to edit it, but short of deleating the feature and starting over I have not found a good way of deselecting an edge.
thank you
Solved by japike. Go to Solution.
You should be able to edit the flange and press the ctrl key while selecting the highlighted edge of the flange you want to delete.
