Inventor Forum
Shape manager unmanageable
34 REPLIES 34
Message 1 of 35
900 Views, 34 Replies
No complex shapes allowed I guess. Out of
curiosity, I tried a boat hull. Don't see a way to do it with the depth
shallower than the width because it would require a loft.The limitations of the
loft being loathe to even touch another face much less join with it prevent
this. It is possible to loft half the hull and mirror it, but then there's a
small gap (guess mirrored faces have an aversion to other faces as well)
which won't fill by any means I have found. Evidentially some edges of a
loft refuse to fillet giving an error, in effect: no edge found. It is
possible to shell one half of the hull by a very small amount (much less than
the radius of the smallest bend) and then it is possible to cut the
face that remains but that leaves remnants of the gap that was left by the
mirror operation. Trying to shell removing both the horizontal and vertical
faces fails. Replace Face will remove the deck faces to make a shell, but won't
thicken.
Unless I'm missing something here, I'd say the
answer to the boat hull modeling question would be: Not a chance, if it needs to
be a real boat hull.
~Larry
34 REPLIES 34
Message 2 of 35
Larry:
I thought I (and of course Jeff Howard) was the only one whacky enough
to mess around with boats in IV.
I'm not sure what you're after but I posted a quick & dirty half-model
in CF under this heading. For most sailboat shapes, I find you have to
do one half and then mirror. Admittedly my submission is a 70's era
shape (I won't give away all of my secrets) done in IV 5.3, but it
works. You ought to see some of the funky elliptical rudders I design.
A fellow by the name of Harry Harrison posted a file under "America's
Cup Hull" that's really neat. I haven't found a covering post anywhere.
Have a good one.
Richard
Larry Caldwell wrote:
> No complex shapes allowed I guess. Out of curiosity, I tried a boat
> hull. Don't see a way to do it with the depth shallower than the width
> because it would require a loft.The limitations of the loft being loathe
> to even touch another face much less join with it prevent this. It is
> possible to loft half the hull and mirror it, but then there's a small
> gap (guess mirrored faces have an aversion to other faces as well) which
> than the radius of the smallest bend) and then it is possible to cut the
> the mirror operation. Trying to shell removing both the horizontal and
> vertical faces fails. Replace Face will remove the deck faces to make a
> shell, but won't thicken.
> Unless I'm missing something here, I'd say the answer to the boat hull
> modeling question would be: Not a chance, if it needs to be a real boat
> hull.
> ~Larry
Message 3 of 35
And for fun, i made richards 1/2 hull complete, shelled with a trim lip and
with bottom paint. Its below his over in CF. Mines in R6 format. Shelling
and sweeping the lip were a synch.
- Drew
Drew Fulford, B.A.Sc. Systems Engineer
Solid Caddgroup Inc, Burlington, Ontario
Phone: (905) 331-9670 Fax: (905) 331-7280
Member of the Autodesk Discussion Forum Moderator Program
Check out my MDT & Inventor FAQ @ http://www.mymcad.com/
"Richard Hintehoeller" wrote in message
news:3DCB210E.2010108@hfx.eastlink.ca...
> Larry:
> Have a good one.
> Richard
> > hull.
> > ~Larry
Message 4 of 35
For some reason your post lock up my OE. Usually it is only the ones that
have all the text showing in the file that do it but yours doesn't. Odd.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
"Drew Fulford" wrote in message
news:AAB76B705BE85AC233C6A12A437E20E2@in.WebX.maYIadrTaRb...
and
> - Drew
Message 5 of 35
Locked mine up as well.
~Larry
and
> - Drew
> > Larry:
> > Have a good one.
> > Richard
loathe
which
less
the
a
boat
> > > hull.
> > > ~Larry
Message 6 of 35
Okay, I put my failure in CF if ya'll care to take a peek. Is this basic, no
control dims, shape (as Drew put it) a synch as well?
~Larry
> Larry:
> Have a good one.
> Richard
> > hull.
> > ~Larry
Message 7 of 35
I reposted as a zipped file
Richard, sorry but i had to add that reverse transom 🙂
Kent, it was a rolled back IPT file. You suppose those are the OE culprit? I
went to see if it locked me up but it was gone already.
- drew
"Kent Keller" wrote in message
news:618D8C8B78180D497E6ADF73D6A34145@in.WebX.maYIadrTaRb...
> Kent Keller
> and
Shelling
> > - Drew
Message 8 of 35
See Larry, it can be done.
Now how do we flat pattern these suckers 😉
Richard
Message 9 of 35
Thought we were going to let ... "them" ... figure out the flat pattern!
Yeah, your shape can be done, but mine is one big whack. I wanted a round
bow at deck level and that's the reason for the radial approach. Glad I
tested it before I adjusted the shape with dims.
~Larry
news:3DCBAF06.7060701@hfx.eastlink.ca...
> Richard
Message 10 of 35
Larry:
My submission was just thrown together as a proof of concept. It may be
possible to apply a fillet to my stem flat or that may be beyond Shape
Manager's current capabilities.
The reason I favour using cross sections instead of the radial approach
is because that's the way I think about yacht design. Even drawing the
station at the bow on the 'Wrong' side of the centre plane and having
the computer work out the profile is a psychological stretch.
It certainly is a nice diversion from the day job.
Richard
Message 11 of 35
Hi, Larry.
For that particular sort of shape, you might try something like the file I put
in CF.
The reason your file was giving you trouble shelling, etc. is the singularity
at the nose. It's causing minute wrinkles and kinks in the surface. Put the
zebra on and zoom in very close. You can see the area and can pick out a 2 mm
edge with the measure tool where the surface is "torn". This is almost always
a problem when bringing all the U / V lines into a single point (despite the
.01 offset), except for a flat triangle surface, and is just about guaranteed
to be a problem when more than two wires converge (the three profiles bring
three wires in). While the .01 offset allows the loft to solve, it probably
contributes to the wrinkles and tear.
Have a good one,
Jeff
Message 12 of 35
Thank you Jeff! That is very cool. I will try one like that. Thank goodness
for intergalactic contacts.
Maybe you know if there is some cosmic limitation to having U & V the same
or opposite or is it something that could be allowed but isn't at present? I
keep running into that limitation and on this adventure it put me in mind of
10,000 seats of Inventor going to the Japanese ship building industry and
wondered if perhaps there may be some effort under way to address this
problem. On the other hand, I guess they could be assuming that you will be
available to consult with the Japanese on how to get Inventor to do what
they may need; ya' think?
~Larry
"Jeff Howard" wrote in message
news:4F6A26B85139BEEE0722F2DB65392DBD@in.WebX.maYIadrTaRb...
> Hi, Larry.
put
> in CF.
singularity
the
2 mm
always
the
guaranteed
bring
probably
> Have a good one,
> Jeff
Message 13 of 35
After taking a cruise this summer on a ship, and looking at the construction
of the various ships we saw along the way, most of the big plates that make
up the hull don't appear to have much curvature. I wonder if they design the
hull to start with as one solid or shape or if they do it as all the
individual plates of steel, each with slightly different bends, and mate
them all up.
Kent Keller
"Larry Caldwell" wrote in message
of
> problem.
Message 14 of 35
Well ... I don't know how they do the models, but having worked at Todd
Shipyards for a short while when I was a kid, I've seen how the ship
fitter's construct 'em. The hulls there, were bent (pad-eyes and jacks)
around the ribs which were welded to the beam to make manageable sections.
Crawling around in the double-bottoms flushing off all those ship fitter's
welds for the pad-eyes revealed quite a few curved surfaces as I remember.
Of course, building them and modeling them are two different things.
~Larry
news:1F84304E0F66EE3466CC9420A5EDBC38@in.WebX.maYIadrTaRb...
construction
make
the
> them all up.
> Kent Keller
mind
> of
and
> > problem.
Message 15 of 35
Hi, Larry.
> U & V the same or opposite .......
I think it means that some of the flow lines (U/V's) are folding or looping
back onto themselves. I notice it most when a profile weight value is too
high. I put an IGES in CF that, I think, illustrates what's happening. It
can be imported into MDT and viewed. The middle surfaces were "blended"
between two planar surfaces with a "maintain" value too large to allow the
transition to solve correctly and causes some of the flow lines to loop back
onto themselves. There are also "good" surfaces and wires shown for
comparison. The different entities are segregated by layers with descriptive
names.
> 10,000 seats of Inventor going to .....
Yea, the CSSC deal. Probably a lot of politics, smoke and mirrors involved
there. "The collaborative capabilities of Autodesk's software will help CSSC
promote digital information exchange among ship design enterprises and ship
owners." Web noodles and balancing international trade deficits... I guess
there's enough of the design that's like any plant installation / mechanical
design (interior structures, plumbing, machinery) that IV would be a valuable
part of the effort and it's possibly an improvement over what they were using
(drafting boards and lofting floor?) if it's the primary design environment.
It would be interesting to get some follow up on stuff like this. Seems like
we always get these news flashes (in the pan?) and never hear any more about
it.
> ...having worked at Todd Shipyards for a short while when I was a kid....
Always thought it would be fascinating to visit a ship yard and watch the
construction.
I don't know the first thing about it, but I believe Kent was correct, in a
sense. I think that large hulls are designed so they can be (primarily?)
constructed from "flat wrap" panels (correct me if you know better) vs. panels
with compound curves. Rhino and, I suppose, (m)any of the specialized hull
design software packages have loft functions that will aid in the creation of
the surfaces where that is the desired result (Rhino calls them "developable"
surfaces and flat patterns can be generated from them). How it would be done
if you are lofting manually... I have no idea, but I guess people have been
doing it for hundreds of years. It's always so humbling to consider things
that have been done for eons that I haven't the slightest comprehension of.
Where's the phrase "I am only an egg." from? 8~)
Message 16 of 35
Jeff:
If you look at a ship in dry-dock, you'll see that they are not
streamlined in the same sense as a racing yacht. Bear in mind that
their primary function is to carry freight. A yacht's shape sacrifices
a lot of stowage volume for the sake of incremental increases in speed.
You can approach the design philosophy from either end. Start with a
yacht shape and trade off the losses in hydrodynamic efficiency (higher
fuel costs) for the additional payload (higher revenue). Conversely,
start with the highest capacity, a rectangular prism, and trade off a
bit capacity as you increase the hydrodynamic efficiency.
As they say, 'Form follows function'.
Richard
Message 17 of 35
Well, that is strange. First time I opened the iges in Inventor the two
surfaces were side-by-side and I could clearly see the flaw. I tried to
import it to MDT but guess I don't know how to do that and couldn't find
anything in help except how to create one. I saved it as a sat but that
didn't work; I think maybe surfaces can be brought into MDT as sat files.
Anyway, I extracted the file if CF again and opened it in Inventor again,
and now the two surfaces are stacked on top of one another instead of
side-by-side, but it's probably still in memory and I will have to start
Inventor again. Can you say how to get an iges surface into MDT? Bet it's a
command-line thingy which I try to avoid whenever possible.
"...profile weight value is too high."
I don't think I know exactly what that means. The profile shape could be
adjusted to make it work, maybe?
"...a :maintain value too large"
This either. No idea what a "maintain" value is.
Todd Shipyard was a long time back and I mostly worked with the sections
that had already been put together, (flushing off welds, burning in decks,
burning out holes, untangling hose, etc.) but I think, for the most part,
the skin started out as plane ol' flat plate. The welders would weld it in
place on one end and weld some pad-eyes on beside the location of a rib.
Then the ship fitter would put a jack on the inside of the rib, use the jack
to bend the plate around the rib and the welder would tack it in place. Then
they would repeat that procedure until that piece of skin was flush to the
ribs.
~Larry
news:5AFE6D472B7C7E7DC30F62186F95C686@in.WebX.maYIadrTaRb...
> Hi, Larry.
looping
It
back
descriptive
> names.
involved
CSSC
ship
guess
mechanical
valuable
using
environment.
like
about
> it.
kid....
> construction.
a
panels
hull
of
"developable"
done
been
things
of.
Message 18 of 35
Relief will be on it's way soon...... I'm presenting a class on translations at
AU this year.... the papers will be available after AU on Autodesk's site, or
may be obtained by emailing me after December 9th....
Dennis
Dennis Jeffrey
CAD Associates - Fort Wayne
Autodesk ASC - Autodesk University Instructor
(260-432-9695 x 221
Message 19 of 35
Hi, Larry.
Sorry, I left out the "how to get into MDT" part. The command is IGESIN.
There are good and bad surfaces superimposed, so turn off or freeze the layers
you don't want visible. If that doesn't work and you are interested, I can
post or email some jpg's.
Profile weight.... referring to the loft dialog (in IV6) Conditions -
Weight. It's value must not be the reason you see the error. I guess it can
be generated when lofting between mulitple profiles, but an example doesn't
come to mind. I may be misinterpreting what the error message is telling us,
too (assuming it's not picked by a random number generator ). Any how, if
you'll post one when you come across it, I'll see if I can offer an
explanation for it.
Maintain value... same thing as the profile weight.
How thick were the plates?
Jeff
Message 20 of 35
I had read this a while back in the Fabricator magazine. It doesn't get
into to much detail, but it is interesting non the less. It sounds to me
they panels are fully formed now days before being welded (if I remember
right....didn't read the whole article)
Anne could probably shed some light on this for us 8^)
http://www.thefabricator.com/xp/Fabricator/Articles/Fabricating/Fab02/02web4
99.xml
Kent Keller
