Inventor General
New Member
Message 1 of 2 (103 Views)
Shaft Generator can't create parts any more
103 Views, 1 Replies
11-21-2013 02:14 PM
I'm using Inventor Professional 2014
I created several Parts with the Shaft Generator, and from one moment to another it always says that it can't update the part file with the new shaft when I press Ok.
Here is the original error, I'm german, so of cause its in german, but i discribed above what it says:
Komponente C:\Users\Manuel\Google Drive\Projekte\Eigene Übungen\Test2\Konstruktions-Assistent\Welle1.ipt konnte nicht aktualisiert werden.
Welle konnte nicht erstellt werden.
Someone knows what to do?
Cheers
New Member
Message 2 of 2 (90 Views)
Re: Shaft Generator can't create parts any more
11-21-2013 03:11 PM in reply to: manuellidl
Found a way to solve the Problem:
I just deleted the folder  C:\users\"current User"\AppData\Roaming\Autodesk\
And now it's working again.
But I still don't know what happened.
Cheers
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
