Is it possible to have an Assembly and/or Presentation as a drawing (.dwg) with a Visual Style of Shaded with Edges? In particular my black .ipt parts look just fine with white/grey edges except when placing the view in a drawing.
Solved by JDMather. Go to Solution.
See Application Options
JD,
I do appreciate the fast response. I have tried that in a variety of colored edges still to no avail. The 2 attachments show what I am trying to accomplish. The need for the edges to be shown in the drawing.
Thanx - Jerry
The problem come from the fact that the IDW/DWG enviroment uses Black to show edges in the shaded view. A lighter color for your part may be your only solution
@Blair wrote:The problem come from the fact that the IDW/DWG enviroment uses Black to show edges in the shaded view. A lighter color for your part may be your only solution
I think you can change the layer color for visible edges.
also visible narrow for tangent egdes.
If there is also a need for 2D drawing black lines - rather than by layer might have to change the color override manually (window select and right mouse button).
Won't that change them for all views on the drawing sheet? I didn't think you could change the Styles for just a single view.
@Blair wrote:Won't that change them for all views on the drawing sheet? I didn't think you could change the Styles for just a single view.
That is why I added a bit more information after the image about manually changing line Properties rather than by layer.
Still early on the west coast, it would also help if I scrolled the screen down all the way as well.
Blair
JD - That was the trick I was looking for. I changed the appearance color of the visible layer in the drawing and it started behaving nicely. Thanx alot.
I am having the same problem now but I use the Vault along with the Inventor.
My problme is that I OPEN a drawing template and change that layer, put in a quick model to see if it worked - which it did, I then remove the model from that temlate and save it and check it back into the vault because it is a template and shouldnt have any other parts in it etc.
I then click NEW --> pick that template, then bring that same model in and the edges have no changed!!!
I have checked around the place and Im posative that the drawing is set to the correct default/standard etc.
Anyone got any idea's?
