Inventor General
Active Member
james.gordon
Message 1 of 5 (185 Views)
Setting default values in the Drawing View dialogue box
185 Views, 4 Replies
01-15-2014 09:04 AM
Inventor 2012.
Is there a way of setting the default values that are displayed in the 'Drawing View' dialogue box?
We wish to make the 'Section Standard Parts' default to ALWAYS rather than OBAY BROWSER SETTINGS.
Ideally I would like this setting to be drawing specific - i.e. can be set via a template rather than require changing settings on each machine - i've seen that you can change it as a global setting in the Application options...
Many thanks,
James
Cadmanto
Message 2 of 5 (153 Views)
Re: Setting default values in the Drawing View dialogue box
01-15-2014 01:08 PM in reply to: james.gordon
James,
I have never done what you are asking, but given the fact that these settings don't take affect until views are placed, I am wondering if you can get this set by creating predefined views in your drawing templates.  Then in those views set this.
Another thought, like you mentioned these can be set in the application options.  With that said, while I have not had any luck doing this, some have.  Change these settings on your machine then export those settings and reload them on your co-workers machines.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
cbenner
Message 3 of 5 (144 Views)
01-15-2014 01:16 PM in reply to: james.gordon
I can't see any way of doing it outside of application options, unless one of the ilogic gurus knows a trick or two.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
blair
Message 4 of 5 (134 Views)
01-15-2014 01:45 PM in reply to: cbenner
The application options was the only think that I could think of as well.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
Active Member
james.gordon
Message 5 of 5 (111 Views)
01-16-2014 12:25 AM in reply to: james.gordon
Thanks all for your help; I think we'll just go with the Application options setting.
James
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
