Inventor General
New Member
magjal
Message 1 of 7 (224 Views)
Set PDF metadata using iLogic
224 Views, 6 Replies
01-09-2013 01:18 AM
I´ve found some iLogic code to print a drawing to a PDF document. After some minor modifications it works just fine, but I would like to add some code which allows med to set PDF properties (such as "title", "author", etc.) with values from iProperties. How can I do that? Is it possible? (I'm new to iLogic).
//Magnus
Regards, Magnus
Message 2 of 7 (97 Views)
Re: Set PDF metadata using iLogic
08-14-2013 11:18 AM in reply to: magjal
Have you ever found anyone to reply to this or a way to do it?
If this response answers your question please click "Accept as Solution".
*Expert Elite*
Curtis_Waguespack
Message 3 of 7 (89 Views)
08-14-2013 11:56 AM in reply to: kmiller
Hi kmiller,
I think will involve a bit of work from the Windows file side of things:
https://www.google.com/#bav=on.2,or.r_cp.r_qf.&fp=196e23fbed2912c1&q=vb.net+write+file+properties
I would search and/or ask this question on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Message 4 of 7 (85 Views)
08-14-2013 12:05 PM in reply to: kmiller
Thanks - I was just going a google search and ran accross this forum first.  Guess i didn't go any further than that.
*Expert Elite*
Curtis_Waguespack
Message 5 of 7 (81 Views)
08-14-2013 12:12 PM in reply to: kmiller
Hi kmiller,
Ooops, I ddin't mean to suggest you hadn't worked hard enough searching (but I can see where my post does come off that way),  :smileyembarrassed:
I just meant that I think the solution will come from working with the Windows file hooks API , rather than the Inventor API. In either case the Customization Forum will be the place to find out.
I hope this helps.
Curtis
Message 6 of 7 (77 Views)
08-14-2013 12:16 PM in reply to: Curtis_Waguespack
Sounds good.  I didn't search enough so it would have been a valid assumption. :smileywink:  I am writng my code in vb.net so I think I can possibly come up with something.  We are just brainstorming some stuff here in regards of the best way to push file data from inventor into another system.
I do appreciate the quick response and will check it out.
Thanks.
New Member
magjal
Message 7 of 7 (64 Views)
08-14-2013 11:23 PM in reply to: magjal
Thank you for your reply! I will check out your suggestions.
I did search the solution to my problem in both discussion groups and google before I posted this question, but without any luck. Guess I didn't really knew how to phrase my search...
Regards, Magnus
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
