Inventor Forum
Self intersecting paths.... Project Geometry
2 REPLIES 2
LyleHardin
2697 Views, 2 Replies
It seems when I project geometry then draw a sketch tracing over that projected geometry, I can't do anyting (offset or flange) with that sketch. It gives me the Self Intersecting paths or loops are invalid for this operation. What gives?
How can I use those projected lines for my sketch? Things work fine in the tutorials....
Lovin' sheet metal and skeletal design, by the way....
Lyle
2 REPLIES 2
in reply to: LyleHardin
Change projected geometry to construction if you are going to trace over it.
LyleHardin
Ah... that's it. A minor thing from the tutorials I forgot.
I also discovered I can use the projected lines as part of the sketch if I don't trace over them.
