Inventor Forum
Self Intersecting Surfaces Helix Profile Sweep
11 REPLIES 11
Message 1 of 12
hardguns
2670 Views, 11 Replies
I am working on Sweeping three helix profiles around a cylinder to create a screw thread.
When I sweep the profile, Inventor gives me the error messages:
"The attempted operation would create a self-intersecting surfaces. Try with different inputs".
or
"The attempted operation did not produce meaningful intersection edges from the face-face intersection. Try with different inputs".
However, this is exactly what I need to create the helix profile I require and eventually increase the size of the Extrusion Sweep profile to 80mm.
When I increase the sweep profile to 80mm I get the same error message about the self intersecting surfaces.
I am working with Autodesk Inventor Professional 2011, 64bit, 8gb RAM, Windows 7, Intel Core i7-2860QM.
Can someone please help me with this problem urgently??
11 REPLIES 11
Message 2 of 12
JDMather
in reply to: hardguns
The help will be faster if you attach an ipt rather than image files.
Message 3 of 12
hardguns
Hi Thanks for your response,
I have tried to attach the file but cannot compress it down enough to add to the thread. 😞
Message 4 of 12
hardguns
Here is a single part file.
This is the middle Helix for my profile.
I cannot increase the diameter of the Sweep profile up to the required 83mm as the surfaces self intersect.
However I need these surfaces to intersect so that I can withdraw that profile from the centre cylinder.
Thanks for your help.
Tom
Message 5 of 12
JDMather
Is this what your really want?
I would do the part completely different (no 3D sketches).
Message 6 of 12
WHolzwarth
Jeffrey, I think, a 3D spline is needed, because of the variable pitch of the helix. I didn't realize the distortions, because I regarded the 3D sketch as basic input. But after finishing my part, I added Extrusionsurface1 and 3D Sketch8. 3DSketch8 would give a better start.
But this part is a challenge, I spent some time with it. And I've asked myself for the reasion of the bad edge contour between the red and yellow face.
Smiley Happy Now I hope to know: It's probably caused by the distortions of the basic 3D sketch.
Walter
Walter Holzwarth
Message 7 of 12
JDMather
in reply to: WHolzwarth
I didn't realize that it was a variable pitch on my quick inspection.
I would try some sort of wrap to cylinder to get the curve or the new Forumula driven curve generation in 2013.
Message 8 of 12
hardguns
in reply to: JDMather
Hi Guys,
Thanks for your help, much appreciated.
JD, yes those parts you have circled in red are part of the helix profile i need to sweep.
How would you suggest I do it without 3d sketches?
I had imported my points in from an excel file using the 3d sketcher.
Is there a patch I can download to use the new formula generation in my 2011 version??
WH i cannot open your ipt file.
Thanks again..
Message 9 of 12
JDMather
The point is that is not a helical curve that I would expect.  I would expect it to be a circle in that view.
Is it correct or not?  Is that really really really what you want?
Message 10 of 12
hardguns
Ive attached the excel file i have used to create the 3d sketch.
however when i add this into Inventor it gives me strange ends on the spline (that i had trimmed in the original ipt file).
how could i constrain this to become more cylindrical without whose parts you had circled in your image?
Message 11 of 12
WHolzwarth
Ouch. While playing with this file, I switched to 2013. No help for a 2011 user.
Here's a Parasolid (minimal filesize). If you need more, send me a mail at wh@holzwarth-cad.de
Walter
Walter Holzwarth
Message 12 of 12
WHolzwarth
Here's a cleaned-up version in 2011, with better shape of 3DSpline of the helix, and modeling improvements.
And now, the edge between red and yellow face is looking much better
Walter
Walter Holzwarth
