Hi all,
I am making some iLogic automated parts which I want to save when I place them in an assembly.
Now I have the folder the file needs to be saved in allready specified in the simple code I wrote but I want to be able to browse the folders to select a specific one.
I run the code by activating it in a Form that pops up when you place the part in an assembly.
The simple save as code I wrote is as following:
Workspace = ThisDoc.WorkspacePath() If System.IO.File.Exists(Workspace & "\Parts\" & "Cable Tray-" & Partnumber & ".ipt") = True Then i = MessageBox.Show("The partnumber you chose is allready in use, choose an other number.", "Save Error", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1) Else If System.IO.File.Exists(Workspace & "\Parts\" & "Cable Tray-" & Partnumber & ".ipt") = False Then ThisDoc.Document.SaveAs(Workspace & "\Parts\" & "Cable Tray-" & Partnumber & ".ipt", False) End If
Can someone tell me how I can browse the folders to select the folder to save the part in when placing the part?
Thanks in advance,
Thijs
Solved by Curtis_Waguespack. Go to Solution.
Hi ThijsdZ,
I think this should work for you:
oDoc = ThisDoc.Document
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
If oDoc.DocumentType = kPartDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
Else if oDoc.DocumentType = kAssemblyDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
Else if oDoc.DocumentType = kDrawingDocumentObject Then
oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw"
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
oFileDlg.FileName = iProperties.Value("Project", "Part Number")
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowSave()
If Err.Number <> 0 Then
MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled")
ElseIf oFileDlg.FileName <> "" Then
MyFile = oFileDlg.FileName
oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As
I hope this helps.
Curtis
Thank you very much! It works very well.
There is just 1 thing I would like to be different if it is possible.
When the screen pops up the name that is selected to save the file as is the normal Partname it allready has.
But since the name is a Library name I use and the number of times I use it in a project is large I want it to take on the name I specified in my previous code ( "Cable Tray-" & Partnumber ).
The partnumber is a user parameter that is also editted in the form before you run the save rule.
Is it possible to get this name as standard name when opening the Save window?
Thanks in advance,
Thijs
Hi ThijsdZ,
Unless I'm misunderstanding, you can just change:
to:
oFileDlg.FileName = "Cable Tray-" & Partnumber
I hope this helps.
Curtis
Hi There,
I think this is exactly what I'm looking for but I'm not sure. 🙂 The work flow I'm aiming for is:
Place iLogic Part ==> Open Form on Placement ==> Description code be generated based on the specification ==> The .ipt is then saved in a specific directory, with the description code as the filename ==> Then the form becomes 'locked' and uneditable.
I'm basically trying to create a way for our desingers to pull in cupboard doors of any size, but build up a common library of files that can be reused by our CADCAM tooling department.
Cheers
GavoGarmo
Actually, if it were editable, but did a save as with the updated filename/description, that would be better.
Hi
I have a similar workflow to this which I need help with. When a part is placed in an assembly I need to have the save as dialog box shown so that the file can be saved with a new name and placed into the assembly with this new name. It will work very similar to the code above however the code needs to run when the part is placed into an assembly (an assembly template can be setup with the rule already in it).
Is this possible with iLogic?
For me it runs when I place the part containing the Rule by adding an Event Trigger to the Rule.
I put the Rule in the 'After Open Document' Event, this means it will run when you open the file, but also when you place it in an assembly.
It wont run again when you open the assembly which you've placed the part in, only when you open the part itself.
Thanks for the prompt reply. I will try it tomorrow when I get in to work and let you know if it worked.
Hi ThijsdZ
I can't seem to get it working, this is what I have done.
I have placed the rule in my part file (Ring.ipt).
In my part file I created the rule trigger (see attached)
I then place the part in the assembly (Test.iam) and nothing happens.
I found where the problem is.
I had already placed the part in the assembly then added the trigger. So when I tried to place the part again it had already been opened so the trigger does not run.
This trigger will only run for the first instance of the part placed into an assembly, for any duplicates the trigger and rule won't run because the part is already open. The same applies for an assembly that is opened with the part already in it, as the assembly is opened the rule is triggered and duplicate parts placed in the assembly don't trigger the rule.
I would like the rule triggered for each part placed in the assembly regardless of it being a duplicate or not. I will create a form and see if I can have the form show on placement of a part as you have it.
I hope this explanation is clear.
I was testing this code in an external rule for Inventor 2019, but needed to open a file instead of save.
I changed the 'SaveAs' command to 'Open', but the file was not opening.
I had to change the code:
from: oDoc.Open(MyFile, False) to: ThisApplication.Documents.Open(MyFile, False)
I hope this is helpful to others.
Jerry
Hi, @Curtis_Waguespack. What is wrong with this macro? Because when I run to call the idw, but don't save the file idw.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Assembly Documents.",vbOK, "WRONG DOCUMENT TYPE") Return End If Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oFileDlg As Inventor.FileDialog = Nothing ThisApplication.CreateFileDialog(oFileDlg) oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam" oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath oFileDlg.FileName = ThisDoc.FileName(False) oFileDlg.DialogTitle = "Specify New Name & Location For Copied Assembly" oFileDlg.CancelError = True On Error Resume Next oFileDlg.ShowSave If Err.Number <> 0 Then MsgBox("No File Saved.", vbOKOnly, "DIALOG CANCELED") ElseIf oFileDlg.FileName <> "" Then oNewFileName = oFileDlg.FileName oADoc.SaveAs(oNewFileName, False) End If oADoc = Nothing InventorVb.DocumentUpdate() oADoc = ThisApplication.ActiveDocument Dim oLast3Chars As String For Each oRefDoc As Document In oADoc.AllReferencedDocuments ThisApplication.Documents.Open(oRefDoc.FullFileName,False) oLast3Chars = Left(Right(oRefDoc.FullFileName, 7), 3) If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim oRefPDoc As PartDocument = oRefDoc Dim oRefPDef As PartComponentDefinition = oRefPDoc.ComponentDefinition If oRefPDef.IsContentMember = False Then oRefDoc.SaveAs(Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & oLast3Chars & ".ipt", True) End If ElseIf oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oRefDoc.SaveAs(Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & oLast3Chars & ".iam", True) End If oRefDoc.Close Next Dim oOccDoc As Document Dim oOccNewFileName As String For Each oOcc As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences oOccDoc = oOcc.Definition.Document oLast3Chars = Left(Right(oOccDoc.FullFileName, 7), 3) If oOccDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim oOccPDef As PartComponentDefinition = oOcc.Definition If oOccPDef.IsContentMember = False Then oOccNewFileName = Left(oADoc.FullFileName, Len(oADoc.FullFileName) -4) & oLast3Chars & ".ipt" End If ElseIf oOccDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oOccNewFileName = Left(oADoc.FullFileName,Len(oADoc.FullFileName)-4) & oLast3Chars & ".iam" End If oOcc.Replace(oOccNewFileName, True) oDoc = ThisApplication.ActiveDocument 'oDoc = ThisDoc.Document oDoc.DocumentType = kDrawingDocumentObject oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw" oFileDlg.InitialDirectory = ThisDoc.WorkspacePath() oFileDlg.FileName = iProperties.Value("Project", "Part Number") oFileDlg.CancelError = True On Error Resume Next oFileDlg.ShowSave() If Err.Number <> 0 Then MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled") ElseIf oFileDlg.FileName <> "" Then MyFile = oFileDlg.FileName oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As End If Next
Hi @aronmatheus ,
It wasn't entirely clear what you were trying to accomplish, but this example creates copies of all the models and any associated drawings if found.
It expects to find the associated drawings in the same folder, with the same name as the models.
I hope this helps.
Curtis
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Assembly Documents.", vbOK, "WRONG DOCUMENT TYPE") Return End If Dim oADoc As AssemblyDocument oADoc = ThisApplication.ActiveDocument oName = ThisDoc.FileName(False) 'without extension oPath = ThisDoc.Path Dim oFileDlg As Inventor.FileDialog = Nothing ThisApplication.CreateFileDialog(oFileDlg) oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam" oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath oFileDlg.FileName = ThisDoc.FileName(False) oFileDlg.DialogTitle = "Specify New Name & Location For Copied Assembly" oFileDlg.CancelError = True Try oFileDlg.ShowSave Catch MsgBox("No File Saved.", vbOKOnly, "DIALOG CANCELED") Return 'exit rule End Try If oFileDlg.FileName <> "" Then oNewFileName = oFileDlg.FileName oADoc.SaveAs(oNewFileName, False) End If oADoc = ThisApplication.ActiveDocument oADocFullName = oADoc.FullFileName '[ process top level drawing oNewFileName = IO.Path.GetFileNameWithoutExtension(oADocFullName) oNewFilePath = IO.Path.GetDirectoryName(oADocFullName) oOldDrawingName = oPath & "\" & oName & ".idw" oNewDrawingName = oNewFilePath & "\" & oNewFileName & ".idw" Logger.Info(oOldDrawingName) Logger.Info(oNewDrawingName) Logger.Info("") Try oDrawDoc = ThisApplication.Documents.Open(oOldDrawingName, False) Catch End Try If Not oDrawDoc Is Nothing Then oDrawDoc.SaveAs(oNewDrawingName, False) 'True = Save As Copy & False = Save As oDrawDoc.close End If '] Dim oOccDoc As Document Dim oOccNewFileName As String For Each oOcc As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences '[ process occurence documents oOccDoc = oOcc.Definition.Document oOccFullName = oOccDoc.FullFileName oLast3Chars = Left(Right(oOccDoc.FullFileName, 7), 3) oNewFileName = Left(oADocFullName, Len(oADocFullName) -4) & oLast3Chars If oOccDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim oOccPDef As PartComponentDefinition = oOcc.Definition If oOccPDef.IsContentMember = False Then oOccNewFileName = oNewFileName & ".ipt" oOccDoc.SaveAs(oOccNewFileName, True) End If ElseIf oOccDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oOccNewFileName = oNewFileName & ".iam" oOccDoc.SaveAs(oOccNewFileName, True) End If oOcc.Replace(oOccNewFileName, True) '] '[ process drawings oName = IO.Path.GetFileNameWithoutExtension(oOccFullName) oPath = IO.Path.GetDirectoryName(oOccFullName) oOldDrawingName = oPath & "\" & oName & ".idw" oNewDrawingName = oNewFileName & ".idw" Logger.Info(oOldDrawingName) Logger.Info(oNewDrawingName) Try oDrawDoc = ThisApplication.Documents.Open(oOldDrawingName, False) Catch End Try If oDrawDoc Is Nothing Then Continue For oDrawDoc.SaveAs(oNewDrawingName, False) 'True = Save As Copy & False = Save As oDrawDoc.close '] Next
Hi @Curtis_Waguespack , there is a mistake in this ruler because save one body only, not all bodies are saving.
Hi @Curtis_Waguespack, I combined your rule with another one and attached it below, however, I can't break the link between the original files by copying the files to the new folder.
'define the active document
CurrentFileName = ThisDoc.PathAndFileName(False)
'create a file dialog box
Dim Filetype As String
'check file type and set dialog filter
Filetype = ".ipt"
ElseIf oDoc.DocumentType = kAssemblyDocumentObject Then
Filetype = ".iam"
ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
Filetype = ".idw"
'set the directory to open the dialog at
'set the file name string to use in the input box
oFileDlg.FileName = ThisDoc.FileName(False) 'without extension
'work with an error created by the user backing out of the save
'specify the file dialog as a save dialog (rather than a open dialog)
oFileDlg.ShowSave()
'catch an empty string in the imput
'MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled")
'save the file
NewDocPathName = ThisDoc.PathAndFileName(False)
'open original drawing
oDestinationDoc = ThisApplication.Documents.Open(CurrentFileName & ".idw")
oDestinationDoc.saveas(NewDocPathName & ".idw",False)
oDestinationDoc.Close
'open new drawing
oDestinationDoc = ThisApplication.Documents.Open(NewDocPathName & ".idw")
Dim oDocDescriptor As DocumentDescriptor
oDocDescriptor = oDestinationDoc.ReferencedDocumentDescriptors.Item(1)
Dim oFileDescriptor As FileDescriptor
oFileDescriptor = oDocDescriptor.ReferencedFileDescriptor
oFileDescriptor.ReplaceReference(NewDocPathName & Filetype)
oDestinationDoc.Update()
oDestinationDoc.Save
oRefDoc.Close
Next
End if
Next
Hi @aronmatheus
It appears I omitted some things in the version I posted in message 16.
here are some test file (Inventor 2019) and the revised code.
I hope this helps.
Curtis
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Assembly Documents.", vbOK, "WRONG DOCUMENT TYPE") Return End If Dim oADoc As AssemblyDocument oADoc = ThisApplication.ActiveDocument oName = ThisDoc.FileName(False) 'without extension oPath = ThisDoc.Path Dim oFileDlg As Inventor.FileDialog = Nothing ThisApplication.CreateFileDialog(oFileDlg) oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam" oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath oFileDlg.FileName = ThisDoc.FileName(False) oFileDlg.DialogTitle = "Specify New Name & Location For Copied Assembly" oFileDlg.CancelError = True Try oFileDlg.ShowSave Catch MsgBox("No File Saved.", vbOKOnly, "DIALOG CANCELED") Return 'exit rule End Try If oFileDlg.FileName <> "" Then oNewFileName = oFileDlg.FileName oADoc.SaveAs(oNewFileName, False) End If oADoc = ThisApplication.ActiveDocument oADocFullName = oADoc.FullFileName '[ process top level drawing oNewFileName = IO.Path.GetFileNameWithoutExtension(oADocFullName) oNewFilePath = IO.Path.GetDirectoryName(oADocFullName) oOldDrawingName = oPath & "\" & oName & ".idw" oNewDrawingName = oNewFilePath & "\" & oNewFileName & ".idw" Logger.Info(oOldDrawingName) Logger.Info(oNewDrawingName) Logger.Info("") Try oDrawDoc = ThisApplication.Documents.Open(oOldDrawingName, False) Catch End Try If Not oDrawDoc Is Nothing Then oDrawDoc.SaveAs(oNewDrawingName, False) 'True = Save As Copy & False = Save As Dim oFD As FileDescriptor oFD = oDrawDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor oFD.ReplaceReference(oADocFullName) oDrawDoc.save oDrawDoc.close End If '] Dim oOccDoc As Document Dim oOccNewFileName As String For Each oOcc As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences '[ process occurence documents oOccDoc = oOcc.Definition.Document oOccFullName = oOccDoc.FullFileName oLast3Chars = Left(Right(oOccDoc.FullFileName, 7), 3) oNewFileName = Left(oADocFullName, Len(oADocFullName) -4) & oLast3Chars If oOccDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim oOccPDef As PartComponentDefinition = oOcc.Definition If oOccPDef.IsContentMember = False Then oOccNewFileName = oNewFileName & ".ipt" oOccDoc.SaveAs(oOccNewFileName, True) End If ElseIf oOccDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oOccNewFileName = oNewFileName & ".iam" oOccDoc.SaveAs(oOccNewFileName, True) End If oOcc.Replace(oOccNewFileName, True) '] '[ process drawings oName = IO.Path.GetFileNameWithoutExtension(oOccFullName) oPath = IO.Path.GetDirectoryName(oOccFullName) oOldDrawingName = oPath & "\" & oName & ".idw" oNewDrawingName = oNewFileName & ".idw" Logger.Info(oOldDrawingName) Logger.Info(oNewDrawingName) Try oDrawDoc = ThisApplication.Documents.Open(oOldDrawingName, False) Catch End Try If oDrawDoc Is Nothing Then Continue For oDrawDoc.SaveAs(oNewDrawingName, False) 'True = Save As Copy & False = Save As Dim oFD As FileDescriptor oFD = oDrawDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor oFD.ReplaceReference(oOccNewFileName) oDrawDoc.save oDrawDoc.close '] Next
