Inventor General
Distinguished Contributor
Message 1 of 4 (194 Views)
Selecting Frame Generator Members In Browser vs. On Screen
194 Views, 3 Replies
11-29-2012 09:07 AM
I commonly need to select frame generator members to change visibility, etc. but since they are all contained in a single frame I need to do this in the browser.  This can be difficult because I need to zoom in on the screen while having the section of the browser visible on screen at the same time.  Is there a way that I can individually select each member in the assembly without using the browser?
Steve Frey
Inventor 2013
Windows 7 Professional 64-bit SP1
HP EliteBook 8470w
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Memory: 16 GB
AMD FirePro M2000
3D Connexion SpacePilot
Message 2 of 4 (192 Views)
Re: Selecting Frame Generator Members In Browser vs. On Screen
11-29-2012 09:18 AM in reply to: SteveFrey
Set your selection Filter to Part Priority.
Also - it looks to me like you have a lot of repeated dimensions - I prefer to use equal (=) constraints instead.
You can window or crossing window select and hit = on the keyboard.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 3 of 4 (184 Views)
11-29-2012 09:54 AM in reply to: JDMather
Thanks.  When you say repeated dimensions are you referring to the top area where the grill bars are located?  I use a formula here (49.438) driven dimension then reference each space divided by the number required.
How would I use the equal constraint?  Highlight select and then hit =  I'll try it.  Thanks.
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
Message 4 of 4 (180 Views)
11-29-2012 10:17 AM in reply to: SteveFrey
I generally have zero dulpicated dimensions unless there is a chance that I know a couple of dimensions might need to be edited independently as the design changes.
You also have a bunch of 90° dimensions rather than Perpendicular constraints.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
