Inventor Forum
Selecting Frame Generator Members In Browser vs. On Screen
3 REPLIES 3
SteveFrey
406 Views, 3 Replies
I commonly need to select frame generator members to change visibility, etc. but since they are all contained in a single frame I need to do this in the browser.  This can be difficult because I need to zoom in on the screen while having the section of the browser visible on screen at the same time.  Is there a way that I can individually select each member in the assembly without using the browser?
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
3 REPLIES 3
JDMather
in reply to: SteveFrey
Set your selection Filter to Part Priority.
Also - it looks to me like you have a lot of repeated dimensions - I prefer to use equal (=) constraints instead.
You can window or crossing window select and hit = on the keyboard.
SteveFrey
in reply to: JDMather
Thanks.  When you say repeated dimensions are you referring to the top area where the grill bars are located?  I use a formula here (49.438) driven dimension then reference each space divided by the number required.
How would I use the equal constraint?  Highlight select and then hit =  I'll try it.  Thanks.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
JDMather
I generally have zero dulpicated dimensions unless there is a chance that I know a couple of dimensions might need to be edited independently as the design changes.
You also have a bunch of 90° dimensions rather than Perpendicular constraints.
