Inventor General
Message 1 of 7 (350 Views)
Select origin?
350 Views, 6 Replies
10-04-2012 05:47 AM
I cannot select origin to constrain sketch with dimension to origin?
I selected Sketch,
expanded origin,
selected mywork plan (xy)
drew rectangle,
input dims,
right click for marking menu,
selected dimensions,
Origin is yellow,
cannot select it and then edge of rect to set dim that will center sketch on origin?
Just like the videos show, but cannot select origin>
Please advise?
spacebeagle
Message 2 of 7 (348 Views)
Re: Select origin?
10-04-2012 05:55 AM in reply to: asbuiltjmh1
Project Geometry
What version of Inventor are you using?  This should be automatic.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Distinguished Contributor
Message 3 of 7 (320 Views)
Re: Select origin?
10-04-2012 09:21 AM in reply to: asbuiltjmh1
You should be able to. Can you post the file with the offending sketch?
Message 4 of 7 (302 Views)
Re: Select origin?
10-04-2012 03:08 PM in reply to: JDMather
Ver. 2013
Thanks for the input.
I went through the 60 tips.
I appreciate your response and the links to resources!
Jim
Message 5 of 7 (299 Views)
Re: Select origin?
10-04-2012 03:11 PM in reply to: asbuiltjmh1
Ver. 2013 Inventor Lt Suite to be perfectly accurate.
Thanks.
P.S. Any other thoughts or suggestions will be immensely appreciated.
Jim
mrattray
Message 6 of 7 (273 Views)
Re: Select origin?
10-05-2012 04:33 AM in reply to: asbuiltjmh1
This is for a full version of Inventor 2013, but I imagine LT has a similar option somewhere.
Mike (not Matt) Rattray
Message 7 of 7 (242 Views)
Re: Select origin?
10-05-2012 09:51 AM in reply to: asbuiltjmh1
Yes, mrattray, that in fact was the step I missed.
Thanks again for everyone's input.
spacebeagle
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
