Inventor General
MechaDraftman
Message 1 of 4 (182 Views)
Accepted Solution
Section view without hidden features
182 Views, 3 Replies
02-04-2013 03:01 AM
When I create a section view in the idw, hidden lines are visible in the cutting part !
How disable these hidden lines and show only the hidden features ?
Thanks.
Greg
Valued Mentor
mpatchus
Message 2 of 4 (176 Views)
Re: Section view without hidden features
02-04-2013 03:44 AM in reply to: MechaDraftman
Double click on the  section view and uncheck the inherit properties from base view box.
Then select the HIDDEN LINE REMOVED icon.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
MechaDraftman
Message 3 of 4 (159 Views)
02-04-2013 04:53 AM in reply to: mpatchus
Thanks but this procedure disable all hidden features.
I just want disable hidden features for section (with hatching) and keep hidden lines where there are no hatching.
Have you an idea?
Valued Mentor
mpatchus
Message 4 of 4 (147 Views)
02-04-2013 06:06 AM in reply to: MechaDraftman
Using a break out view, the only method I know would be to manually select the hidden lines and turn their visibility off. (RMB - Visibility).
Mike Patchus
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
