When I create a section view in the idw, hidden lines are visible in the cutting part !
How disable these hidden lines and show only the hidden features ?
Thanks.
Greg
Solved by mpatchus. Go to Solution.
Double click on the section view and uncheck the inherit properties from base view box.
Then select the HIDDEN LINE REMOVED icon.
Thanks but this procedure disable all hidden features.
I just want disable hidden features for section (with hatching) and keep hidden lines where there are no hatching.
Have you an idea?
Using a break out view, the only method I know would be to manually select the hidden lines and turn their visibility off. (RMB - Visibility).
