Inventor Forum
Section view from sketch issue.
6 REPLIES 6
517 Views, 6 Replies
I need an urgent solution to my issue.
  1.  I have created section view from a sketch (a line constrained to the projection of a work plane) from my derived part to my drawing using the "Get model sketches ".
  2.  When i update the iassembly and update the the view using model state the view tries to update but throws an error see attached document.
  3. When i delete the section line and create a section line manually ie. by creating a normal sketch in the drawing the same model gets updated without any error.
  4. Any help would be appreciated
    BR
Kishore
Tags (3)
6 REPLIES 6
okaleja
If it is possible, could you please send me your dataset at otoDOTkalejaATautodeskDOTcom for investigation?
Oto Kaleja
Oto Kaleja
Software Engineer
Thanks for your reply .Yes i am sending you right now.
I have found out the possible bug in inventor.
Here is the data set for producing the error.
Note:
It happens only for iAssembly derived section views.
The errors that are showing up during the updation of the iAssembly is equal to the no. of dimensions used for constraining the section line.
Now I find that even for ordinary models the error is coming. When the model updates the error throws up. I wonder whether my working method is wrong. Any help would be most appreciated.
The error is happening in IV 2012. Is this the issue in all versions of Inventor. Or what is the correct method of working with section views from sketch?
Attached is the most basic form of the error. Any one can reproduce it and tell whether its the issue only for me or its for all.
