Inventor General
Distinguished Mentor
rdyson
Message 1 of 8 (288 Views)
Section View Properties in iam
288 Views, 7 Replies
12-10-2012 12:57 PM
Using half / quarter section view, I know how to section CC parts.
How do I NOT section custom parts?
There has to be setting somewhere. Anyone know?
Cadmanto
Message 2 of 8 (282 Views)
Re: Section View Properties in iam
12-10-2012 01:32 PM in reply to: rdyson
You are talking about something similar to the Display Options under "Section Standard Parts" where you can select which groups you want sectioned except this in assembly mode I am assuming.
Or are you looking for something where you can randomly select individual parts that you don't want sectioned in the assembly model.
Either way I am not seeing anything that does this in the model.  If there is I would like to know myself as well.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
New Member
J.Pieters
Message 3 of 8 (256 Views)
12-10-2012 11:59 PM in reply to: rdyson
I guess you are looking for 'participate in assembly and drawing sections' you find this checkbox in the part environment
tools --> document settings --> modeling tab
i hope this helps!
rdyson
Message 4 of 8 (242 Views)
12-11-2012 06:44 AM in reply to: Cadmanto
Curtis,
There is obviously some setting that allows / causes CC parts to not participate in sectioning in the assembly environment. (see below)
I was looking for a way to make one of my parts behave the same.
john.retzlaff
Message 5 of 8 (238 Views)
12-11-2012 06:59 AM in reply to: rdyson
Edit the part you don't want sectioned and uncheck this box in document settings.12-11-2012 8-58-00 AM.png
John Retzlaff
rdyson
Message 6 of 8 (230 Views)
12-11-2012 09:21 AM in reply to: john.retzlaff
Thanks you! Knew it had to be somewhere.
Cadmanto
Message 7 of 8 (210 Views)
12-11-2012 10:34 AM in reply to: john.retzlaff
John,
Thanks for the tip.
It is a shame that this is not built into the actual section command itself, like I have experienced in other softwares.
Where you can select components not to be affected while in the command.
Best Regards,
Scott McFadden
john.retzlaff
Message 8 of 8 (207 Views)
12-11-2012 10:35 AM in reply to: Cadmanto
Yes, sure would be nice if you could change this at the assembly level.
John Retzlaff
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
