I wonder if anyone can help me out here. I'm trying to change the linetype of the section line in an idw. I want to be able to increase the size of the gaps between the dashes (similar to the way you can control centre marks and lines. Sounds simple, but when I go to Format - Standards, I'm unable to change the linetype for Section view lines. It seems to be the only linetype that's restricted to 'By Standard'. I realise that, if I change the lineweight, then the spacing changes but I don't want the line to end up looking like it was drawn with a magic marker.
The only other way around it that I can see is to hide the line and sketch it in manually using an appropriate linetype. Does anyone know of a better solution?
Cheers
WT
