Is there a way to display the section property of a T beam? Specifically, I'm looking for the second moment of area in units of in^4 (Ixx). iProperties provide me with the mass moments for the axis in units of lbmass in^2 under the physical tab (global properties). I'm sure this information is somewhere, I just can't seem to locate it. What am I missing?
Solved by henderh. Go to Solution.
look for the region properties in the sketch environment. This assumes you extruded the "T" from a profile sketch.
