Is there a way to only show the second level of assmblies of a BOM in a parts list while making a idw drawing? I have an assembly that references two other assemblies that I want to get all children of the two assemblies and form a parts list. It is a bit complicated to explain but see the picture for SecondLevelBOM.png for more info. I can find the First Level BOM properties in the Parts list under the BOM Settings and Properties but cannot find the second.
Hi jeremy_Ross,
I these steps will get the results you're after, but you might need to make a few adjustments after you try it:
I hope this helps.
Curtis
