Inventor Forum
Screw threads exported as .STL files
4 REPLIES 4
drumrboy44
8225 Views, 4 Replies
I've been trying to make a male and matching female screw and fitting for attaching two parts that will be 3D printed. However, whenever I export the part to an .STL file, the threads do not show or print properly. Any ideas on how to fix this in Inventor?
Thanks in advance.
-Drumrboy44
4 REPLIES 4
JDMather
in reply to: drumrboy44
How are you creating the threads?
You must model them.
Look closely (very closely) at your model - the Thread and Hole-threaded tools in Inventor create cosmetic bit-map image representations of thread, not real thread geometry.
pcrawley
in reply to: JDMather
Try the thread modeller.  You'll find it on this page on the Autodesk Labs site:
http://labs.autodesk.com/utilities/ADN_plugins/catalog
Peter
Peter
BLHDrafting
You might want to try this add-in :- http://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=autodesk.appstore.exchange.autodesk.com...
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
JDMather
in reply to: BLHDrafting
If you use an add-in to create your threads - double check that it uses the correct thread form (last time I checked it didn't, but it has been a while since I checked).
