Inventor General
JamieVJohnson2
Message 1 of 5 (275 Views)
Scrambled screen view
275 Views, 4 Replies
06-06-2013 08:41 AM
In Inventor Professional 2014, under certain screen sizes (by lcd, not necessarily pixels), inventor will display a scrambled screen that makes it impossible to view the work to be done.
1. Radeon HD cards 5900, and 6900 series are doing this.
2. Nvidia Quadro FX 4800 is not doing this.
3. Simply adding a second open drawing, and having it display the tabs at the bottom, resolved the scrambling.
4. Only the drawing area is scrambled, not the menus, or Browers.
5. Reducing the program, or drawing window may fix the issue.
6. Templates have nothing to do with it.
7. Application options May have something to do with it, but I can't find which ones.
8. Cycling thru all hardware options has no effect.
9. Installing (clean) the latest video drivers has no effect. (even betas)
10. When the screen scrambled, dragging the main program window to undock it from monitor 2 to monitor 1 would cause Inventor to crash (most of the time).
My machine has been doing this since I installed 2014.  My supervisors computer was not.  Then when I imported the application options, it began to do so.  I MUST resolve this issue today, without installing a bunch of new video cards.  Please help if you can.
Thank you,
jvj
cbenner
Message 2 of 5 (259 Views)
Re: Scrambled screen view
06-06-2013 10:51 AM in reply to: JamieVJohnson2
Well, there are two clues in your list.  The different video cards, and the Application Options.
Do you have any other machines that are NOT doing this?  Can you compare the Options to see what is different?
As much as you don't want to hear this, have you verified the compatibility of the Radeon graphics card with IV2014?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
JamieVJohnson2
Message 3 of 5 (253 Views)
06-06-2013 11:07 AM in reply to: cbenner
Yes the application options are the problem, specifically in the registry, when I wipe out the key:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0
Inventor recreates the bare minimum.  The problem is gone.  Reconstructing the options I add one feature at a time, I have crossed the threashold of problems at adding Color Schemes back (manually had to import them into the registry).  Also the color schemes I have are from earlier versions say R17.  However in reverse, removing the color schemes key did not fix the problem, so something else is getting added after I add the colorschemes that is causing the real problem.
I can revert the registry back to just before the color schemes were added, and all is good again.  Being a member of the beta testing group, I never merged by 2013 data with 2014, because I didn't want to muck up my 2013 live projects by accident.  I would love to get down to the exact registry key causing the problem (probably only 1).
Apparently Autodesk doen't 'test' graphics cards anymore.  The last Radeon on their list was something like a HD2900, which is way older than HD 6900, however, I can not rule out AMD software in this issue as it relates to Autodesk's call to it's drivers.
So at least for now I have a work-around... No color schemes, go with default, and don't load them in at all.
jvj
cbenner
Message 4 of 5 (246 Views)
06-06-2013 11:49 AM in reply to: JamieVJohnson2
Well, all I can say is you are fairly brave doing anything inside the registry.  I wouldn't try that, no matter what.  I've done damage that way in the distant past.
ChrisB
JamieVJohnson2
Message 5 of 5 (222 Views)
06-06-2013 04:12 PM in reply to: cbenner
Remove these registry keys:
[HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0\System\Preferences\Display]
"OGSSupport"=dword:00000002
"OGSMultiSampLevel"=dword:00000002
"OGSFallbackLevel"=dword:00000000
Or at least set this MultiSamp to 0.  I finally found the exact source of the scrambled screen issue, introduced in 2014.  Does anybody know what these keys are supposed to do?
jvj
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
