Inventor General
New Member
guneskupelioglu
Message 1 of 2 (144 Views)
Scale a part
144 Views, 1 Replies
01-06-2013 02:36 AM
Hello, I am a new inventor user. I made several parts but I made their dimensions wrong. For example instead of 62mm I made 6,2 mm. I want to scale them but after scaling I want to use them like an original part. I want to change the dimensions when needed. Is it possible? In the forum I read that deriving a part is solution but hot it works? I didn't understand exactly. Thank You
JDMather
Message 2 of 2 (126 Views)
Re: Scale a part
01-06-2013 07:06 AM in reply to: guneskupelioglu
I recommend that you simply do the parts over from scratch (and correctly this time).
Almost every part I have ever made - I did at least two attempts and often many many more than two.
The experience will be good and it won't be nearly as much work as you might think.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
