Inventor Forum
Saving in sketch mode
1 REPLY 1
Anthony
675 Views, 1 Reply
One suggestion for Autodesk for Inventor 2013, the ability to save while in sketch mode - if you're going to be spending a lot of design time sketching then this needs to be addressed so that the drawing is automatically saved. Otherwise if Inventor crashes (which it often does) while you're busy sketching away you loose your work.
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
1 REPLY 1
in reply to: Anthony
yes, i've made the same suggestion recently
it's worse in 2012 because the view changes when you exit sketch edit if you're looking at the sketch straight on.
