Hello. When i create a drafting i use ISO.idw template. I delete the default title block and the default border and then i create my personal title block and border. How to save the new title block and the new border somewhere in "Inventor's memory" and use them in other draftings?
Solved by CCarreiras. Go to Solution.
Hi!
After you configure your own title block and border, save it as a Template, and that's it!!
You can also save in the template other specification if you will: Fonts, Dimension styles, part lists, etc)
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
