When I "save copy as" dwg an IDw, I have an error with some ellips.
from IV 2013 to Autocad Mechanical.
Is it solve with IV 2014?
Thanks.
I just tried it here, and the issue disappeared, with side views of a parabola, as are existing on the nuts.
But
Walter
Walter Holzwarth
As mentioned in the other conversation, I've modified the ini file. But the result remains the same with those ... things with bolts sightly rotated.
The same situation occurs when I use a .dwg (inventor) instead of .idw
Anyways, I hope to find time to update to INV 2014. I hope it'll help.
