I don't know what has happened, suddenly I am not able to save an Inventor DWG to Autocad DWG.
It is something I occationally do for sending yo some customers.
I have done this since V. 5.3 and never had any problems until now.
This is the message that occurs:
Registry key Version has invalid data type.
Problems encountered while saving the document.
I am currently using 2014 Professional, it has worked even in this version until now, something must have happened, I wish I knew what...
Any help appreciated.
My system specs:
HP Elite Book 8540W
8 gig Ram
240 gig SSD Drive
Quadro FX 1800M Graphics
Best regards / Nmt
Solved by bob_holland. Go to Solution.
What does your add-ins screen look like under Translators?
Have you made ANY system changes recently? Any un-installs, new software, updates, drive updates, windows updates, etc.?
I have attached a PDF on instructions on how to reset your Inventor user environment.
Please try these steps and let me know it this does or does not resolve your issue.
I want to thank you for your suggestions.
Resetting the registry did the trick.
I recently uninstalled V. 2013, something must have happened with the registry at that time.
Anyway, thanks again!!
/ Nmt
