Inventor General
New Member
Message 1 of 1 (87 Views)
Save XML file when a rule starts in iLogic
87 Views, 0 Replies
01-09-2013 07:12 AM
Hi
I would like to save a new XML file every time a rule in iLogic starts. It would be nice if i could use something like the rule bellow and instead of just saving over the same file every time the rule starts, it should be a (save as) and ask for a new filename every time. Or instead of the "filename" just add the date and time.
iLogicVb.Automation.ParametersXmlSave(ThisDoc.Document, "path\filename.xml")
Is this possible to make? I would be glad if someone could help me with this problem.
Niklas
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
