I'm still running into this error nearly 4 years later. I've also found that I'm not the only one (for example: Identifying Assembly-Context-Required saves )
I think the error is related to performing copy designs on frame generator assemblies.
Anyway, I just thought I'd ask again: anyone find any success in overcoming this?
I'll take a shot at this though I have seen issues like this before. it's always been with Skeletal files and not with Frame Generator models (don't use Frame Gen too often actually).
It seems like you're caught in a type of update/synch loop (I'll assume you're also using Vault).
The quickest fix we've done if it's possible, is to open/checkout the top level assembly file AND all its subcomponents.
Yes, this could be a massive assembly and undertaking, but what doing this does is it forces all files to be updated/synched thus eliminating the error.
Just not sure if this is the same issue you are seeing but it always worked for us. i just hope, for your sake it's not a large assembly.
Note: you might also run into issues with Released files if you are using a PLM like Vault Workgroups, etc.
If so, you'll need some help from your CAD Admin who'll have the permissions to jump threw the hoops to clear that up (which is what I had to do for users when they ran across this error)
I have run into this when I created one frame.
I do remember when the save dialog window came up I selected "No to All" and then just selected the skeleton or frame assembly file I was working on to change to "Yes" and that seemed to work.
But I have to ask. How many skeleton files do you have burried into this one frame assembly?
Maybe there is a break fown of communication between these sjeletons because there are too many or too many layers deep? Just a thought.
Scott,
Very good points about the skeletal files. I've seen people just go crazy when making skeletal models and basically include every parts profile, etc. It got to the point it was unusable. Just like with constraints, you can paint yourself into a very small corner.
I've seen some nightmares with using skeletal models in an enviroment of numerous users on a project, thus I tend to stay away from them depending on the need and project.
Again, just like constraints, they can be your greatest ally or your greatest foe.
Thanks for the replies - your input is very much appreciated.
This is actually, in my opinion, a very simple assembly. I've attached the example. The offending file is Skeleton4234.ipt
What's really odd to me is that the assembly responds when the base sketch is edited. So the skeleton file is evidently updating, even though the error message would indicate it's associated with another document.
Frame Generator skeletons, as well as Tube & Pipe runs, are both types of files that can only be saved from within the Parent assembly in which they were created. I think I'm reading this thread right, igonore me if I'm not.
When you start a new frame from within an assembly file (using FG), it creates a new Skeleton file, and a new Frame file. These 2 files cannot be opened individually, modified and then saved. They need to be modified from within the full assembly in which they were created. And can only be saved from the top level there. I don't know exactly why, or what references and dependencies are created that make this true... but it be true. Same is true with Tube & Pipe, a Run created in an assembly cannot be opened on it's own and modified, it must be modified from within, and saved from the parent assembly.
So... again, I hope I read the question right and didn't just waste your time with a bunch of nonsence.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
This problem still exists! I have a co-worker who is experiencing this issue right this very moment.
I believe the assembly that he is working in is the top level for that skeleton. However it will not save and will not let him check the model in until a full save is completed.
The last post on this thread was in 2013 it seems. Have there been any breakthroughs?
Hi! In normal condition, the error is trigged only when you are trying to save a document in a state that the document is also opened within an assembly or a drawing and there are unsaved changes there. The error tries to prevent "stepping toes" behavior.
If you have a repeatable example, please post it here or send it to me directly (johnson.shiue@autodesk.com).
Many thanks!
Manage -> Purge -> Check "Purge Styles from Child Documents" = fixes this. Or, at least, it corrected the error in my example. Your mileage may vary.
For context, the error in my example occurred when I generated a "mirrored" copy of a frame generator assembly. Essentially take a rough shortcut.
I opened the assembly containing the skeleton file and went to Manage/Rebuild All and then saved it and it worked!
@Ampcontrol.Mackay, @eduardo.godinez2 , & others,
Thanks for your feedback & for trying to help all these years later!
Hi All,
I have found a work around to remove the error message "Some of the modified dependent documents can only be saved in the context of another document that is not being saved. These dependents will be excluded from the save."
1. Looking down the save dialogue box locate the file ('s) Invalid context (must be saved with another file)
2. Copy design this file and rename the file.
3. Delete from your local drive the original invalid file
4. Reopen the the top level assembly in inventor
5. Skip all on the resole file box and resolve the file to the newly copied, renamed file.
6. Update the model and resave. The error message- "Some of the modified dependent documents can only be saved in the context of another document that is not being saved. These dependents will be excluded from the save." will no longer be displayed.
Hope this is helpful.
